Rosstafarian
- Mar 17, 2022
- 70
Not sure this has been covered, apologies if it has.
I am mounting 6 bifacial panels on a garden pergola. They will be over a white crushed rock walk way about 8’ off the ground, so I’m hoping to get some have from the backside of the panel.
The racking structure, which is custom made, will cover selected areas of the panel. Basically two 2” cross members will run perpendicular across the back of the panel. That’s all that will shadow the back of the panel except for maybe some grape vine leafs that get out of hand.
Are the beck of the panels half cut? Meaning, if part of the panel is covered the opposite half of the panel or 1/4 of the panel is active? Am I over thinking this?
Thank you.
Thank you.
