Hello, I am now planning to build my own lifepo4 battery. I have 32 cells with a capacity of 100Ah . Is it better to connect each two cells in parallel and use one BMS?
Or do I connect each 16 cells in series, then connect two series in parallel and use one BMS?
Or do I connect each 16 cells in series and connect them in a parallel with the other string and use 2 BMS 2( bms for each series?) Thank you.
