Can the EG4 PowerPro + 6000XP be installed in a Class A RV?
AlwaysRt
Are the approved mounting orientations beside top up sitting on a floor or wall mount? It looks to be the PERFECT size solution for me but I would need to mount the battery either on its side or back.
I wish Will would remember his roots (I have been subbed a longgggg time lol) and at least mention mounting options for RVs - no real need to do RV mock-ups, just add a minute to videos stating mobile install orientation options.
Some of the issues with using a 240V split phase inverter in an RV are due to the 50A shore power connection. I strongly suggest using something like the Victron Multiplus II 2x120V and I can assure you I'm not usually a fanboy of the blue simply due to price but the functionality and design of this unit outweighs other choices when it comes to 50A RV power.
The Multiplus II 2x120V was designed with RV use in mind that has a 50A shore power connection. You will need a separate charge controller but I think this is really the way to go.
