i found a company selling wind turbine combo charger controller with divert load, where also abundant power from solars can be used for example for heating...
as i went through its cycle it works like this(BMO)
1: AC3 phase power comes from turbine to manual switch and then to rectifier, making DC
2: positive cable from rectifier goes to relay switch AND to battery positive pole too
3: negative from rectifier goes to negative pole of dump load AND to the battery negative pole in the same time
4: voltage sensor monitors if the battery is fully charged and then triggers the relay, which moves all the power to the dump load, until battery voltage goes down to set value, then the dump load is disconnected and power goes back to battery and again and again. lets suppose this is setup correctly and it only diverts abundant power from turbine after battery is fully charged...
for purpose of this question, lets forget the dump load part of circuit
question to this scenario is: can a battery be charged directly from rectifier? without any dc-dc stepup/down converter?
isnt the voltage from rectifier jumping up and down based on wind speed turning the turbine?
maybe i missed something, but im afraid, that there can be situation, when for example standard 12v battery will be charged with voltage higher then 14.4v coming directly from rectifier without dc/dc converter and also opposite situation may happen, that there will be not high enough voltage coming from rectifier, if wind is slow, lets say 7V and battery will not be charged during these periods...
Digital All In One Charge Controller with LED Meter for 3 Phase and DC Systems
Digital 440 amp hybrid charge controller for handling multiple charging sources. Awesome for wind, solar, and hydro. Pair with your own dump load.
windandsolar.com
