John Simmons
- Feb 1, 2020
- 44
Hello everyone,
I am on a 47 foot sail boat and my 800AH AGM battery system is in need of replacement.
I have 500W of solar going to a morning star mppt controller. I contacted morning star and they have sent me a programming sheet to reconfigure for LFP. No worries there.
I also have a 90 amp Balmar alternator with a mc612 regulator. Balmar was also kind enough to send new programming values for LFP. Also no worries there. The alternator has the alternator protection device on it in case of an accidental disconnect while the engine is running.
There are also separate AGM start batteries for both the 59hp Volvo diesel and for the 6kw Northern Lights diesel.
There is a battery switch that will allow you to parallel the house bank with the Volvo start battery, (1, 2, Both, Off) for the boat systems or for starting the diesel.
There are two different 120v based programmable battery chargers. One for the start AGM banks, the second for the house bank. The manufactures have also been great to work with.
There is also a link lite battery monitor for amps in/out of the house bank, Ah used, etc.
My goal is to replace the 800Ah AGM with 400Ah LFP. I would like to use the 100Ah Fortune batteries that Will recently reviewed. I will be buying 16 of them.
My questions are:
1) Should I build 4 12V packs, then put them in parallel like the drop in replacement batteries?
2) Should I do as Will showed in one of his videos and go with 2 cells in parallel, and then put 4 of these double cells in series for 8 per battery. Then put two of these in parallel?
3)Go for it all, 4 cell packs in parallel. Then series up these 4 for 16 per battery.
What does everyone think would be the best option? Case 1 uses 4 BMS, case 2 needs 2, and with case 3 I would also use 2 in parallel.
High draw loads are the windlass at 80 Amps, and in the case of the start battery for the Volvo going bad, probably the same.
I have also read about placing a AGM in parallel with the house bank in case the BMS goes offline. Others advocate not using a BMS at all and simply controlling your charge and closely monitoring the discharge in order to protect the batteries.
I got 10 years of daily liveaboard use out of my old AGM's so I must have been doing something right.
Any help would be greatly appreciated.
My questions are:
