In Will's charge profile post (https://diysolarforum.com/threads/r...le-for-diy-lifepo4-batteries-sticky-post.5101) he covers volts. But what about amps?
The converter in my RV is specific to lead acid batteries and isn't programmable, but it can charge at 45 amps. Consequently, I'm looking for a new converter. I'm not sure what amp rating to go with.
The Victron Skylla-IP44 appears to be capable of up to 60 amps and has a LiFePO4 charge profile. However, it's very expensive.
The Victron Blue Smart IP67 has some nice features but as near as I can tell, it goes up to only 25 amps. Much less expensive.
Progressive Dynamics has multiple chargers that support a LiFePO4 charge profile, ranging from 30 to 80 amps. More expensive than the one above.
The 5500w generator on my RV can handle any of those. When I'm using the generator to charge the batteries it's because there isn't enough solar and charging quickly is ideal. But is 80 amps acceptable?
I will have the EVE 3.2v 280Ah cells, either in a 2p4s (single BMS) or a 4s2p (one BMS for each battery).
