Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 21,284
If two people are perceived as knowledgeable, but one is known to be more knowledgeable, it helps to identify that person.
Both approaches may work. Unless one of us identifies a safety hazard, feel free to try both.
I do make mistakes, and get absent minded/careless. Last time I did that, I happened to live to tell the tale.
Looks to me like existing array is 86% the Vmp of new array. Even if current doesn't increase when pulled to lower voltage (it does), worst case simple estimate is you get 86% power from new array. KISS, just accept those figures and enjoy more power.
Multiple orientations is good, keeps batteries charged longer through the day and reduces likelihood of clipping.
I would like to have seen Andy turn off the MPPT and allow the array to sit at Voc. I suspect he would have measured a small current flow through the lower voltage array.
Less than you might expect. I thought I/V curve of panel would indicate current drawn when backfed, but I tried it with one panel in a dark room (looking for light emission), and around Voc it only drew about 1/2 of Isc or less.
Yes ... but can you translate @Hedges for me ?
Can it be done ... or can't it. (I think I understand that it can be done)
Just go for it, report the results.
