livingthefreeway
Hey All.
I have (4) 12v 300ah Enjoybot brand batteries hooked up in series to power a 48v Victron system. I’m trying to understand what are the optimum charge settings for the battery, and although the manufacturer was quick to respond with specs when I emailed them, some of the numbers seem like they might be a bit off.
Hoping someone else can take a look and confirm or deny my suspicions.
Here’s the specs sent over from Enjoybot to plug into my Victron system:
DC Input Low voltage shutdown: 51.40v
Absorption voltage: 58.40v
Repeated absorption time: 12.00 (hours)
Float voltage: 55.2v
Repeated absorption interval: 1.00 (days)
Charge current: 20A recommended. 50A Max (amps)
Absorption time: 2.00 (hours)
Charged voltage: 53.60v
Tail current: 2.0% (percentage)
Charged detection time: 30min (minutes)
Peukert exponent: Default
Charge efficiency factor: 100% (percentage)
Current threshold: Default
Time-to-go averaging period: Default
Time-to-go discharge floor: 20% (percentage)
By comparison, here is Enjoybot’s spec sheet for their all-in-one 48v battery
That spec sheet is for just one 48v battery (with one singular BMS), so not sure if there should be any difference in my settings run (4) 12v batteries in series.
In general, do these specs from the manufacturer look right?
Specifically the charged voltage of 53.6v seems rather low, as well as the inverter low voltage disconnect of 51.4 both seem rather conservative.
I know this is what I get for going with a ‘no-name’ battery manufacturer. But it was the only option available to me at the time.
Thanks for any input you can share
