eddie1261
I don't know if I should find this remarkable or not. I have been living under the apparently wrong assumption that "this appliance" consumes what it consumes no matter what the power source is. I just tested that with an O2Cool fan and my Chromebook, and I found that I was wrong.
The Chromebook came with the adapter to plug it into the wall, like everything does. When I plugged that into my Goal Zero and looked at the output, with that wall wart plugged into the 110v out on the Goal Zero it used 19w and 1.5 amps. I then plugged in the 12v and saw it used 10w and .9 amps. Same device. I watched Will's current video on both so I was doing exactly the same thing in both cases.
Then I plugged in the O2Cool fan with the 110 power source. It read 18w and 1.4 amps on the lowest speed. When I switched to the 12v power supply and it was 4w and .3 amps. I DID notice on 110v that the fan , set on the same speed, ran a little bit stronger
So the question is whether appliances should consume the same amount of energy on the 110v out as they do on the 12v out, In this quick test, they seemed to be more efficient on the 12v output. That tells me to use the 12v outs in the trailer rather then the inverter. Thoughts? Comments?
