Battery Bob
Good day! I am trying to build an easy-to-use online battery and inverter sizing calculator for people in South Africa, or anywhere in the world to use. With load-shedding in South Africa, many people want some solution to the power outages (rolling blackouts) and people get all sorts of advice from different people and end up being confused about what solution will suit their needs the best.
The idea is to first - have the people select the appliances that they plan to use (from a dropdown menu) Each appliance has an estimated prefilled wattage power consumption.
Then a global variable for the number of hours that the person wants backup power (which gets multiplied by the W of the appliances)
The challenge comes in when there is coffee being made (how many cups? additional variable?) a hairdryer for example is around 1000W, but only for 10 minutes in an hour and seldom more than once a day for the average household. Even a water pressure pump, will only start a couple of times per hour, but I will need to add a value for x number of minutes per hour of runtime.
I thought it would be a good idea to get some advice from the community as we all have different opinions and from that, I would like to build the best, simplified, easy-to-use but fairly accurate free-to-use online calculator. I know there already exist calculators, but they just don't feel that user-friendly to me.
I am looking forward to your input regarding the different appliances you would suggest and also how you would approach the problem. In South Africa, power outages are normally 2 hours or 4 hours at a time.
