Going solar off-grid means understanding and accepting certain constraints and restrictions relative to your former grid-tied lifestyle with unlimited power (at a price). In a nutshell, you will be constantly trying to balance cumulative intermittent Power Consumption (all household loads) with power Regeneration from the sun through your PV panels - with all the uncertainty that entails: shade, seasons, weather, snow, etc. Batteries will provide the buffer between the two. For best results, you and your family members should be aware of this balancing act, accept it, and, in some cases, willingly modify your power consumption behaviour accordingly. Failure to do this will not result in a happy implementation! Living off-grid will not be business-as-usual: minimizing power demands at the outset is a good place to start.
Also, before you begin a DIY Solar project you should ask yourself if you have these personal characteristics:
- are you comfortable with the uncertainty of living the balancing act as described above?
- are you comfortable with math? You don't necessarily have to be a STEM person (Science, Technology, Engineering, Math) but designing and running a solar power system will definitely require some calculations. Are you OK with that?
- Assuming you are not already familiar with electricity, do you have the time and inclination to learn something new? We all live busy lives. You'll have to commit some time to this, otherwise just hire a professional tradesman to do it like you would with any other improvement around the house for a job that you don't understand enough about to DIY.
