keepinpalid
I am building a system for my van and have the following setup:
- Eg4 3000EHV 48v
- 2 standard lifepower 4 batteries (1 set of posts on each)
- 48v to 12 v converter for 12v fuse
I’m trying to keep it simple and planned on putting two rings on each post like this:
- Battery 1: 3000EHV incoming connection and outgoing connection to second battery
- Battery 2: Incoming battery 1 connection and outgoing connection to 12v converter
I believe I would actually connect the positive from the 3KEHV to one battery, and the negative to the other battery but you get the idea.
Why do some people recommend a bus bar and what would be the benefits if I did go with a bus bar setup?
If I did use bus bars, would I have one bar for the positive connections and a second bar or the negatives? And then the 3K and batteries and the 12v converter would all connect to each of the bus bars (+ and -)?
Thanks for the advise!
- Eg4 3000EHV 48v
