TommyG-UK
Photon catcher
I'm building a 200W solar shed at the bottom of my garden, I'm about to install 4x new 100ah 3.2v LiFePO4 cells and after watching some of Will's videos it got me thinking.
Do I need to use a BMS if I bottom balance first?
I won't be pulling any huge loads in the shed, typically about 70-100 watts for a few hours a day to power things like shed/garden lights at night and phone chargers.
I'm also about to purchase a Victron MPPT SCC (which I intend to program to only enable charging between 20-80% to hopefully elongate the life span of the cells), along with a low temperature disconnect sensor.
So, because of my system’s relatively small size and power draw, will I need to use a BMS after I have bottom balanced the cells? or could I get away with only using an active balancer permanently connected to the cells?
