Overtaxed
Been considering solar on the house (the RV already has a full compliment) for some time now. I called up Duke this morning and wow, they've figured out a great way to stop more solar from coming into the system!
My current rate is ~11c/kwh on what they call "RS" (Residential Service).
For solar, they install a bi-directional meter and move you to a rate called R-STOU (Residential Solar, Time of use). This has variable rates, but summing up (full details for anyone who's interested linked below)
Critical Peak - 27c/kwh
Peak - 17.5c/kwh
Off peak - 11c/kwh
Super off peak - 8.5c/kwh
Peak: 6AM-9AM; 6PM-9PM
Off peak: All hours not in peak or super off peak
Super off peak: 12AM-6AM, March 1-Nov 30th
If you look at the peaks, those are times when solar is basically at 0w and your electric consumption is likely to be high, morning getting ready for work and right after work until you go to sleep. Also, that "critical peak" is at the company discretion, no more than 20 day/yr.
So, summing all this up, I'm thinking solar might not make a lot of sense because I'd have to give up my good rate to get it.
I'm wondering if anyone else is in this situation and if you've done something like a "zero export" system to get around it. If I don't ask for a bidirectional meter, and I don't export any power, can't see why Duke would even need to know I have solar (still need permits from the town, of course), right?
My current rate plan:
Solar plan with Duke for SC:
Peak - 17.5c/kwh
Off peak - 11c/kwh
