Educate me on the on the Santan solar panels.....there seems to be many different choices...snail trails, discolored, cracking, etc., what will get you in trouble or what will last reasonably. Do you mind saying what you paid and what shipping was?
SanTan
I just got
- 7 used NEO 335w panels at $89e
- 19 new surplus no warranty REC 370w panels at $155e (I personally love the REC TwinPeak2 panels. I have 18 on my house now. They handle shading better than most do to the design)
I just tested 2 of the NEOs and 1 of the RECs. Both came in over ISC (short circuit amps), and under VOC slightly
Used Neo
- 43v voc (should be 47) but my conditions may not have been perfect. Solar noon, hot, clear to slightly hazy
- ISC was about 11.3 amps, and it was supposed to be 9.8a.
- So Total is over spec
New REC TwinPeak2s
- 43.4 voc (should be 47)
- ISC was about 12.6 amps, and it was supposed to be 10.08a.
- So again ... over spec
All 7 NEO panels look perfect in condition. I only tested 2, but I'll test all 7 before I install them. I got 1 extra. I need 6
I did not dig to the bottom of the stack for the REC because they are new surplus, but the first 3 were in perfect near new condition. Only a few scuffs on the side of the frames. And that is how they were advertised.
To your question, I would avoid, Snail trail, blemished, cracked, dicolored, damaged or cracked backs etc. Stick with either surplus new or good used condition with the 1 year santan warranty. So unless you are mounting in a easy excessable place ... like not on a roof, get surplus new or used. Only get the really cheap ones if you can easy change them out. But get several extra if you want get the cheap
And honestly, now that I have the NEO 335s in hand, I would probably just ordered all 25 as NEOs. All 7 I got were in mint condition. For $89e plus $200 freight you cannot go wrong. They seemed to have a boat load of them too in both locations.
When you open up the Santan Solar Panel page, pick the size group you want (300-399w etc) and then scroll down. Santan seems to list the worse condition ones first.
