I'm using the eg4 6000xp with a pro tran transfer switch that is connected to 10 circuits on my main home panels. I don't have grid input going into my inverter. My understanding of using a transfer switch means that the system becomes bonded because of the use of the transfer switch because the main panel is bonded. If this is the case, I should disable the bond in the inverter correct? Would this be a safe way to set up this system?
