WattAboutThat
- Dec 15, 2021
- 123
I currently have Two EG4 Battery Racks, each with 6 48V Batteries 100Ah of storage per battery, so 600Ah storage per rack.
I don’t understand how to calculate the DC breaker size i would need to place on each rack.
I understand that each individual battery has a breaker, but I want to be able to protect each entire rack, and also have the ability to isolate one rack, leaving the remaining rack functional, in case I would need to service a specific rack.
Signature Solar has this
https://signaturesolar.com/nader-dc-circuit-breaker-60v-200amp-with-enclosure/
60V 200A breaker - but how do i know/calculate
that 200A is sufficient???
currently there will be 2 18kPV inverters
that can max charge and max discharge at 250A to and from the batteries (per inverter),
and I intend later to add 2 more inverters.
I can not find the Amps (as opposed to Ah)
for the batteries, but assume that it is the Amps being drawn from inverters, or supplied by inverters that determines the amps.
if that assumption is correct, then i could have
up to a max of 500A (2 inverters x 250A) in or out, (if later add 2 more inverters, then 1000A),
so 200A breaker would seem too small per battery rack. And I have not been able to find larger Amp DC breaker similar to above.
Sorry to continue with idd questions
but this is my next issue of confusion.
Please advise.
Thanks
Please advise.
Thanks
