Bustermaine
I haven't downloaded and run EG4s BMS-TEST,exe yet so any pointers for using will be appreciated.
I'm trying to setup a backup to keep an aquarium pump running for several days in the event of a power failure. I've set up two EG4 Lifepower4 48 volt batteries connected to a Victron Phoenix 48/1200 invertor to run a 50 watt pump and 300 watt heater when power is lost. Power is switched with a automatic transfer switch, The problem I'm running is If there isn't a load on the inverter the BMS dissables the battery output and the circuit breakers have to be reset to enable power out. What am I missing using the EG4 batteries?
