JonF
I’m planning to build this system: https://www.mobile-solarpower.com/mobile-48v-system.html
Original YouTube source: “Build a Mobile 48V Solar Power System in 10 minutes”
Using the following main components:
- EG4 3kW Off-Grid Inverter | 3000EHV-48 | 3000W Output | 5000W PV Input | 500 VOC Input — https://signaturesolar.com/eg4-3kw-off-grid-inverter-3000ehv-48/
- EG4-LifePower4 Lithium Battery | 48V 100AH | Server Rack Battery | UL1973, UL9540A — https://signaturesolar.com/eg4-lifepower4-lithium-battery-48v-100ah/
- ALLPOWERS SP037 Portable Solar Panel 400W — https://iallpowers.com/products/allpowers-400w-portable-solar-panel
- Do I need to buy a circuit breaker for the LifePower4 battery (or for anything for that matter)?
- Is there a minimum voltage / wattage I need from the AllPowers solar panels when connecting to the inverter? Do I need to put several in series to make it work? Or will one 400w panel do the trick?
