EVE 304ah came in
Nonlin
So my EVE 304AH batteries from 18650 battery company in Georgia just came to my house.
I'm doing some testing and I'm getting 6.0 mega ohms of resistance?
This seems way off yes?
A multimeter uses DC to measure the impedance, but the voltage in the battery messes with the results. An Impedance tester uses AC, usually around 1Khz, to make the measurement. Testers like the YR1030 and YR1035 do an okay job, but they're not lab instruments. You're likely to get different readings than specified for the batteries, which will only annoy you. I agree with the above - just build.
You can't measure battery impedance with regular multi meter. You need special battery impedance tester for that.
Ah ok, didn't know that. Isn't a range / accuracy issue? Does it mean absolutely nothing?
IR testers apply a known load during measurement. It's a dark art. Even with the correct equipment, results are not directly comparable between different equipment and methodologies.
Factories have advanced equipment and then run the same exact test on different cells and then their results are useful, because the test equipment and methodology is a controlled factor.
Would be nice if they gave a test sheet for the batteries with the results of their testing
18650 provides test reports I thought. But who can trust a spreadsheet anyway. Buy from a reputable seller, which you did, check your QR codes aren't sanded, which they're probably not, then build and see how many kwh's you get. That's the test, build it and use it.
Just FYI
Please take some time to read over the many tutorials building your batteries. There is many things your going to need to do to be successful.
In my experience 18650 does not over promise. I dont think you will be disappointed.
For a quick gauge of capacity, if they are sitting at 40% SOC right now, you should see that it takes an appropriate amount of kWh to reach full charge. Once decently top balanced, they should stay very well balanced even with a small passive balancer.
Just FYI
This would be also my recommendation. Start with some theory before going much further with your build. Huge lithium batteries are not the best starting point to beginner, some precaution is recommended.
Your mishap with the multimeter was rather harmless but someone could also attempt to measure amp-hours with the multimeter current range by shorting the battery with the multimeter. :whistle:
I used a multimeter to test the impedance of the 3.2V lifepo4 battery, and it showed 15mΩ. But I used an impedance tester to measure it before, and it was 0.21mΩ. Amazing!🤣
And the seller told me that it is correct to use an Impedance tester to test. But she didn't tell me the reason.🤣😅
Sand off the top layer to remove the anodizing you will get much better results. These terminals have a thick layer of anodizing that adds resistance.
