Greeting from the solar stone age. I built tiny 100 watt 12 volt system in 1985 and have been using it ever since as sole source of juice. Now expanding to 400 watts. I'm hoping to use the same wire I installed way back: 10 gauge copper running 50 feet to six golf cart batteries wired up as 12 volt bank. Can I successfully do the expansion by wiring the panels to pump out 24 volts into a new controler, the new fangled kind, mmpt, the kind that takes in 24 volts and puts out 12 for the battery? Or is there another better way to do it? Also, any controler recomendations? thanks, Nick
