Vigo
So it's not on a lawn tractor per se (my little tractor picks up ~1000lb on the front, ~500lb on the back, 4wd, diff lock, has a PTO etc etc) but the charging system is basically identical anyway.Have you had any issues with the charge coil on lawn tractors messing with the BMS?
Since im using a PWM charge controller i think even a 'pure' DC source would still appear 'choppy' after it gets PWM'd to the battery, so conceptually i dont think the rectified-but-unfiltered dynamo output would be any worse or different from just using a PWM scc in general.. This is just my assumption based on my understanding, but i have NOT checked AC ripple on my charging circuit to verify what it actually is!
I don't believe i've had any issues relating to the charging system BUT i do have a mystery drain or parasitic draw somewhere which i haven't spent the time to diag yet. The batteries have no issue cranking the tractor when they are charged, but the last two times I used the tractor i had to jump start it because the batteries were dead. It's probably something simple but i haven't investigated it yet.
