I'm looking for help and advice to setup forecast based battery charging and smart electrical panel and smart thermostat to get the most utility out of a battery bank while minimizing the amount of energy I buy from the grid?
Say peak TOU energy costs are 6-10am and 5-8pm.
If today it was very sunny but tomorrow it will be very cloudy. I want a battery system to know that and raise the discharge limit overnight to like 50% while normally it will allow discharge down to 5% before switch to the grid. That way at 6am there will be enough battery left to get through the peak TOU from 6-10am and 5-8pm without need any energy from the grid during those times.
The forecast would also know from past data the trendline curve of how much energy the heat pump uses for how cold it will be the next day. If it will be extremely cold the next day maybe the battery needs to be kept at 80% instead of 50% to have enough energy to make the house off-grid from from 6-10am and 5-8pm. If energy is used quicker than expected then the smart thermostat will turn down the temp from 6-10am and 5-8pm from say 74 F down to 70 F to reduce loads. How does the system know if energy is used quicker than expected? It would use 15 min resolution energy data from past days with similar outdoor temperature to predict the energy use pattern that will occur today.
In the summer time lets say peak TOU is 3-8pm.
On a very sunny summer day, if forecast predicts the battery will hit fully charged before 3pm, I'd like the smart thermostat to crank the setpoint from 75 down to 70F to use up the excess energy. And this the precooling also means the air conditioning won't run as much from 3-8pm. And I want the battery+pv inverter to export/sell energy to the grid from 3-8pm, leaving only enough for the house to make it through the night off grid. So the next morning when it will again be very sunny the battery starts the day at like 10% charge.
These are just some example scenarios but they cover the bulk of the situations this smart forecast based battery charging system would need to negotiate.
Thoughts on the possibility of making such a system work? Any ideas on how to start? What equipment (battery charger, smart inverter etc.) to buy to get started?
Thanks
Best
-Edward
Thanks
Best
-Edward
