G guidecca New Member Joined Oct 5, 2020 Messages 322 Aug 8, 2023 #1 (16) EVE 2.3v 280Ah cells = how many amp hours? Thanks.
R Rocketman Solar Wizard Joined Sep 27, 2020 Messages 1,993 Aug 8, 2023 #2 It depends on the voltage of the battery you are making. When cells (or solar panels) are hooked up in series their voltage adds, but the amp stay the same. When hooked up in parallel the voltage stays the same and the amps add. So if you are making a 48v battery - 16@3.2v = 51.2v and 280Ah If making a 12v battery - 4*3.2 = 12.8v and 4* 280Ah = 1120Ah - either way the same energy.
Bob B Emperor Of Solar Joined Sep 21, 2019 Messages 8,993 Aug 8, 2023 #4 That would be 560ah at 24V 16 cells would get you qty 2 .... 8S packs or 1 2P8S pack .... either way 560ah at 24V
