I have little time left for research and weeding through forumns so hoping I am not violating policy but…..
My current Travel Trailer setup
1- 12v 200Ah Amperetime battery
1- Aimspower 12v 3000A pure sine inverter charger.
I split the hot side of the rv panel so that the inverter powered only the microwave, and the outlets for 2 tv’s/starlink/laptop/2-19inch monitors, and converter for 12v rv systems.
The refer, fireplace, small outdoor freezer, and AC only have power when on shore power or generator.
I would either like to add another inverter/charger that could synch with existing to double the rated output to 6kW continuous, or continue with split panels and if my current inverter will not synch, or buy one new 6kW inverter/charger put the panel back to factory, and use current battery and inverter for portable power.
I also want to buy:
4-12v 300Ah batteris ( or as many as is needed to support my inverter load)
8-Bouge RV Yuma CIGS 200watt flexible solar panels (or as many as is needed to meet my full time RV living, given that I winter in parker AZ, and summer in the notthwest.
I would appreciate any advise as far as whether to stay 12v or go 24v system, the number of solar panels needed (given brand/type is not changeable), voltage and number of batteries (brand is not changeable)
Lastly, anybody willing to provide a schematic and list of charge controllers, fusing, cabling etc, would be very appreciated.
Funds will be in hand june 15 and I need to be on the road ASAP as its getting HOT
I also want to buy:
