Using a 200Ah lithium battery. I am looking for fuse sizing for the bolt on battery fuse. Maximum load on the system is 120 amps with everything switched on. Should I use a 150amp fuse or a larger fuse like a 200amp? Any information is much appreciated. Also wire size chart shows 120 amps I should use 2awg wire from battery to busbar, does this sound correct.
Thanks
Thanks
