I recently picked up a Goal Zero Yeti 1000X for emergency use purposes and have been putting it through its paces. Earlier today, I noticed that during charging, the Yeti would seemingly "reset" itself. Specifically, the display shows incoming Input Wattage (from solar or AC) and then suddenly drops to zero for a few seconds before spiking back up.
I initially noticed this behavior when connecting a couple of solar panels to charge up the Yeti. At the time, the Yeti was at a 45% SoC so it seemed like the perfect time of the day to test out solar charging. Yet when I noticed the power fluctuation on the display, I was puzzled. I tinkered with the cabling a bit, disconnecting and reconnecting everything for good measure. I ultimately dismissed my observation as user error since the behavior seemed to correct itself once I got everything reconnected.
A few hours later, the solar panels had charged the Yeti from 45% SoC to 98% SoC. The sun had reached its low point for the day so I decided to top off the Yeti using the base model AC charger, just to get that last two percent. This is where things went haywire. They Yeti immediately began resetting itself over and over. The display would briefly show ~30 Watts of Input before jumping back down to zero. I tried powering off the Yeti and disconnecting/reconnecting the power supply to no avail.
I've previously been able to charge this unit to 100% so I find it odd that suddenly things aren't working quite right. Has anyone else seen this behavior? For context, at no point during any of this was the Yeti providing power to any connected devices. The Yeti was simply recharging.
