A 100 amp disconnect has 100 amp fuses holders. They can accept fuse sizes of 65 to 100 amp. You need reducers to accept fuses for a 60 amp fuse holder. Which will accept 35 to 60 amp fuses.
If you already have overcurrent protection at the array, you could argue that you only need short protection at the disconnect. But, it would be a hard sell.
Is it ok to use 125 amp braker to a 100a non fused 100% duty double throw manual transfer switch to 125 amp main breaker sub panel?
Also does anybody have any recommendations on solar ready 200a main meter combo panels that will accommodate CTs?
