I was testing our emergency backup setup today and when the battery reached 90% the inverter temporarily shut down and restarted. I had setting 1 set to UTL and setting 13 (Utility to Battery Transfer Voltage) set to 90%.
Based on how I'm using this inverter, I think I need to change setting 1 to SBU and set setting 13 to 100% so that the inverter never tries to switch over to another mode. I don't have solar, so this setting will ensure battery is the primary. When the inverter is powering the house, it is on batteries only...acting like a standard backup generator. I never want it to switch modes until it is disconnected from the load panel and replaced by my gas generator to be used to recharge the batteries. Only then should the inverter be looking to go into battery charging mode from utility/generator.
For those of you who have a Growatt...am I interpreting setting 13 properly? Below is what the manual says:
Thanks for any insight...
Here is my setup:
Here is my setup:
