Hey guys,
I have a strange problem going on with one of my growatt inverters.
So i have 2 growatt 6K split phase units and 1 EG4 6000ex (just for reference).
Both Growatt units have solar and are drawing from the same battery bank.
Both units have been working issue free for 2 years.
Each unit feeds a separate sub panel and the load at peak is 50%.
Battery bank size is 1200ah about 57,000 watt hours.
Battery bank drops about 20% over night currently under summer conditions. Lots of capacity left.
So what has changed, well one unit and this is only at night, starts having voltage issues.
The voltage will show 119v at the receptacle and then it will randomly drop to 96v and back up to 117v and on and on and on.
This happens all throughout the night. Come morning when solar is available, everything is 100% normal again.
Now the other growatt inverter which is connected to its own panel, has zero issues, no drops in voltage, it runs like a champ.
The EG4, runs without issues.
I have tried moving the AC output on the affected inverter to another subpanel and the problem follows.
There is no error codes that show up on the inverter.
The inverter shows everything is operating normal, but its not.
Im not sure what to check with this unit.
I am planing to move everything over to the EG4 once i receive my second 6000ex and parallel the unit.
However i would like to get this growatt unit working so that i can use it elsewhere.
Anyone have ideas as to what to check next?
There isnt any warranty left as it is just passed the 2 year mark.
