I just installed 2 100Ah batteries and am seeing a ton of information about what my settings should be.
I work my system pretty hard while the sun is up and I'm trying to stay as close to a full battery as possible when the sun goes down.
Does this look right?
Epever Tracer CC with 400w of panels.
My controller settings:
Temp compensation: 0
Over volt disconect: 14.6v
Charge limit: 14.4v
Over volt reconnect: 14.4v
Equalize charging voltage: 14.3v
Boost charging: 13.8
Float charging: 13.45
Boost re connect charge: 13.4v
Low voltage reconnect: 12.8v
Under voltage reconnect: 12.8v
Under voltage warning: 12.0v
Low voltage disconnect: 11.6v
Discharge limit voltage: 11.0v
Equalize duration... 0 min
Boost duration... 120 min
Charge limit: 14.4v
