MrM1
I'm Here, But I'm Not All There
on the EG4 install video from Signature Solar, they said pressure tested it to 500 psi with the nitrogen.What pressure is used for pressure testing? 200? 400? A quick google showed 600psi.
That is 600 psi inside the lines, not 14 psi on the outside. Pretty drastic difference.
But, if you are confident in your flares and seals a vacuum test is likely good enough
