Help paralleling JBD-AP21S002 7-21S 300A BMS
Aabshir
quick over view of my system.
2 packs each contains 2p16s 280a LFP. Total of 62 cells.
Each set has brand new JBD JBD-AP21S002 7-21S 300A BMS. Individually they work like a charm.
I have two bus bars way too oversized for this but when I parallel these BMS one doesn’t get charged only one does. Eg. If I turn the first one off the second starts to get charged fine. Turn the first one back on. It senses the other BMS and it won’t get charged. It shows everything fine but won’t charge or discharge as long as the other BMS is doing something.
I can’t comprehend what is going on here. I am trying to balance and match the packs voltage one pack is 56.7 and the other is 56.8. Can that be the issue ?
Got these BMS from batteryhookup.
thank you so much for all the awesome things you guys do.
Ab.
Not a single response ? Where is Steve ? 🤣. Just emailed batteryhookup about this too. You’re suggestions are greatly appreciated
Are both packs at the same voltage? Could one overrun the other with current and it’s going into protection?
Something doesn't add up. Can you post more photos and screenshots of your settings?
I'm running 3 smart JBDs in parallel.
If I remember correctly I had to isolate each one with a charge to get them to work.
Edit Found post.
Hi
I have just discovered from LLT ( the manufacturers) that their BMS cannot be wired in parallel. I cannot get any sort of technical reason - just NO - sorry - not allowed etc.
THis might be your problem.
Just had a look at the technical spec sheet and parallel function is not allowed.
Looking ta the dates this is very old news but might help someone.
Hi
That's baloney. 3 in parallel here and I'll be adding more.
So what exactly did you ask? Is it possible that they misunderstood your question?
Agreed, baloney. I have 2 working in parallel and never read or heard anything that paralleling was not allowed.
That doesn't make sense. The BMS can't sense anything since they're separate packs for all intends and purposes, just happened to be connected to the same bus bars. There is nothing to sense.
Are you sure both packs are at the same state of charge though? Internal resistance can be different at different states of charge (and same voltage), meaning the one with the lower internal resistance will draw more current. If one pack is at 80%, and the other at 40%, the 40% one will pull most, if not all, of the current.
Hello Aabshir!
Did you solve your problem? I have the same BMSs and run four of them parallely. I know a similar issue like you and I may only offer a workaround.
My BMSs do the following:
- if no load is connected, they switch on, stay on for 2-3 secs and switch off
- exactly the same, when there are other BMS active
- if there IS load, and there are no other BMS connected, the BMS remains on and works as expected
Now the funny part: if the BMS didn't switch off, it remains on, even if the load is gone again.
Now, I connect the other BMSs and everything works fine ;)
Of corse, you have to take care that the voltage isn't too different, so that the current protection won't be activated. so stay within +/- 1V.
So if I have to work on the battery, I just remove the DC wires (I use Anderson connectors) and switch off only the battery I want to work on. The, after the work is done, I attach the one battery that was switched off and apply some load, so the relay keeps closed. Then I plug all the other batteries, that never were switched off.
Best regards,
Thomas
