Help with Pace BMS Comms
andynotts
Ireland
Hey, I have a Anenji battery pack. It's a 51.2V100AH battery. It has a Pace BMS but I cannot get any reliable communications with it. The seller sent me a BMS Tools v2.04 which they say should be able to talk to the battery. I'm getting nowhere. I have 3 RS232 cables, 1 from Amazon, 1 from the seller and 1 I made myself. I swapped the RX and TX on mine and that gives me some success but not much using MJDB Tools v2.7. Also with RX and TX swapped at least Putty will loopback text, so I think that was the right thing to do.
I've got it configured as a lead acid battery on my inverter currently but would really like the BMS to communicate properly. Can anyone offer any help for setting the protocol on the battery?
You need to set the battery ID to 1 on the dip switch (ID 1 = 1st switch up, the others down).
Then you should be able to use the BMS Tools on rs232 or just get com with your inverter (brand ?) thru CAN or RS485.
You can download a more recent version here : https://www.gobelpower.com/downloads_ap27.html?cate=4 (HS 2.03. Yes, it is more recent than PBMS 2.04 or even 2.5 ...).
Actually it looks like a Pace BMS but display is different as it is written "Lanpwr" on it ...
Might be a customized version of a Pace or a copy, then Pace software not compatible.
Worth trying asking Lanpwr directly if they can point you in the right direction...
I’ve tried a Solis and Voltronic inverter. Tried connecting to the rs485 and Can port. I had some success with rs232, flipped the rx/tx wires and used MJDB tools v2.7 it could read some information but not the CAN or rs485 protocols
I had a heck of a time trying to communicate with my Sungold Batteries that us the Pace BMS. There are a bunch of rj-11 rs232 cables that won't work. The one(s) I found that worked were from Sungold and from Current Connected (2-part cable) for an SOK battery that used the Pace BMS
Or you can rewire one of those non-working cables like I did after figuring out the correct wiring - see my posts on that.
Here - https://diysolarforum.com/threads/i...-split-phase-solar-inverter.71345/post-924209
and other posts in that thread.
Good Luck!
Keep us posted here!
and yes that PbmsTools software will work and this cable will connect to Solar Assistant running on a Raspberry Pi.
I'm using PbmsTools v 2.5
First, do you have the pinout of each RS485 port.
The EG4 Lifepower4 batteries for example use pins 1&2 as an RS485 bus as well as pins 7&8 as a second RS485 bus in the same RJ45 jack.
I purchased a RS485 to USB Converter:
RS485-USB-Converter
Using a spare cat5 cable, just cut of the RJ45 connector on one end, remove about 3 inches of the outer insulation then you can connect the correct pair of wires to the RS485 to USB Converter and plug the RJ45 connector on the other end to the correct port on the battery.
Look at the RJ45 connector on the cable (With my tired old eye I use a magnifying glass) and determine the order or the wires.
With the RJ45 connector locking tab facing away from you and the bare pins facing you can determine the color of the wire to each pin. pin 1 will be on your left and pin 8 will be on the right.
T-568B RJ45 pinout
Pin Color
1 orange/white
2 orange
3 green/white
4 blue
5 blue/white
6 green
7 brown/white
8 brown
For exampe, in my case if I want to communicate to my batteries on pins 1&2, I connect the orange/white wire to the B- on the converter and the orange wire to the A+ on the converter, If I want to communicate to my batteries on pins 7&8 I connect the brown to the B- on the converter and the brown/white wire to the A+ on the converter
For the EG4 pins 1&2 are generally used for end user communications such as the User software or Solar Assistant and pins 7&8 are used when the battery is placed in Host/Master mode by settings its address to 0. The BMS in Host/master mode will then poll the other batteries in thwe stack on pin 7&8. The EG4 Communication hub als acts as a Host/Master BMS and pols all batteries on pin 7&8.
Hopefully you will be able to determine which pin combination works for you. With an RS485 to USB Converter you can try any number of combinations without the need to purchase cables only to find they do not work.
Good Luck!
I will look at this over the weekend. Spent all day talking to Solis customer support getting the energy meter working
Hi , I am amazed at the information I've found on this forum ! I am struggling with a protocol issue . I have a Sunwise 48V batt with BMS Pace 15s. I cant get it to communicate with my MPPSolar 5048MGX inverter. I have connected the battery BMS via serial adapter to rs232 . In the PBMSTools for changing protocol, the Inverter Protocol showing "Paceic" , but none of the software versions will allow me to change it. They all pop up with "Write Error" . I have tried the other PBMSTools which allow you to see and adjust parameters ( It allows me to adjust almost everything except the inverter protocol) and tried to change the protocol in "System Config" , but the same problem, same error. I'm at a loss, any help would be appreciated. Thanks PS. I didn't realise that this rabbit hole would be so deep!!
There are way to many "BMSTools" or "PBMSTools" software out there.
passwords:
1: 123456
2: paceadmin
3: calculated from current date/Time in the format ddmmhh (day minute hour). You add 10 to the minutes and the hours are in 24hr format;
for example current date/time is 04/09/2024 9:45 PM. The password entry would be 095521. Add 10 minutes to 45 and 9 PM is 21 hours
for example current date/time is 04/09/2024 9:51 PM. The password would be 090122. Add 10 minutes to 51 which kicks you into the next hour so 9 PM becomes 10 PM which is entered as 22 hours
It appears that the protocol change function is hard coded for a battery address set to 0. I have also not been able to get it to work via the batteries RS232 port however (I have not yet tried it) it may work if connected via an USB to RS232 converter connected to the battery to battery RS485 port
With the correct password entered a couple of new tabs will appear. You need to click the "Upper Settings" tab and you might have to change the "Protocol Ver". The protocol version is sent with every command to the BMS and is part of the command validation process. The protocol version varies from BMS to BMS and in some instances where different manufacturers use the same BMS they may code a specific protocol version that will often prevent other software from working.
I do not know what protocol version your BMS uses; some are 20, 25, 26
At some point I will try connecting to my SunGoldPower batteries via the RS485B or RS485C port and see if I can change the protocol.
I know if I use the SOKTool software I can change the protocol using the RS232 port
Hi Marionw, Thank You for your response . I have tried using passwords 123456 to change protocol, the password is correct, but it shows write error. Paceadmin didnt work in that version of PBMStools . The Soktool Doesn't allow me to change the protocol but using the password Paceadmin I managed to get the two new tabs showing and my battery's protocol version is 25 , but I may talk to the supplier about changing this first ! Have you had success changing this setting? I really don't want to damage anything or not be able to go back ! See the PDF the supplier sent me , I have bought the connector and will try this when it arrives , I hope its not the exact same as the premade serial adapter to RJ11 which I have already used! Round and Round we go!! I have also bought USB to RS485 so will try it when it arrives.
  • Changing Protocol .pdf
HI, i am in the same situation with my Ananji Batteries... i am not able to establish a communication via RS232?!?!?
I tried various cables, adapters and program version?.
Everytime i get a "TIMEOUT"
Any Idea?
The communication between Battery and Inverter is runnung with Polyntech protocol.
But my problem is, that the batteries will cut off power when they are 100% loaded. The message is "pCOV"
Think that mean "protect cell over voltage"
I dont know why the inverter will not decrease the charging power.
wolud be nice if somone can help me
thanks
Christian
Any Idea?
thanks
Christian
It appears (from the product page) that those only have RS485 communication (Or maybe not #10 below but wiring....) so you have to go that way or use an adapter of some sort. Sorry I can't help much more than that. maybe @marionw ?
It would always help if the electronic version of the users manual were provided, if possible.
The RS485/CAN is normally used for Inverter/BMS Closed loop communications (from Master BMS normally address 1).
The "double" RS485 ports are normally used for battery to battery communications.
The RS232 would normally be used for battery monitoring by your computer or even Solar Assistant (one or the other, not both at the same time)
Did your battery come with what is often referred to as an "Upper Computer" cable (I don't know why they refer to the PC as an Upper Computer).
I am basing this on the picture you provided in your original post:
This looks very much based on the "Port" configuration layout in your picture much like an SOK or SunGoldPower battery (who cloned who)
I use this RS232 to USB cable between my PC and the RS232 port on the "Master BMS" (address 1 SunGoldPower battery)
Note the pinout on the cable as seen on the amazon web page.
I also use the SOKTool.exe software downloaded from Current Connected website:
Current Connected SOK
Current Connected SOK Manual
Use last link at bottom of page.
Hope this helps....
hi.. thanks for response..
the battery is nearly the same as in the first picture (i have an 200Ah)., and yes you are right.. RS485/CAN --> for Inverter (this works); "double" RS485 --> to other batteries (also works) only RS232 will not work with the Upper PC !!
I tried the same cable as you, also one with the CH340 Chip, also a self made cable with different usb adapters
I tried all Versions of programs that i found, SOK, BMSTools (version 1.05 1.06 1.07 2.03 2.5 2.5FN), OrientPower 2.04, BatteryMonitor and and and
no way to get this working
As always, and I am sure you have, make sure you are selecting the correct serial port.
Download Device Monitoring Studio and run is trial mode
Start SOKTools (or whatever software you are using) and then start Device Monitoring Studio, select the correct port then capture the traffic
It is possible the manufacturer is using a different "Protocol Version" and/or CID1 in their communications. Most PACE devices use "Protocol Version" 0x20 or 0x25 and CID1 0x46. SOKTools is built to use 0x20 or 0x25 and 0x46
Also on the battery, go through the menu and verify you are selecting the correct baud rate in the software tool that the BMS port is set to use.
Also try setting your first or "Master" battery to address 1 and all others with increasing addresses
This is a sample of what the Device Monitoring Studio software shows while running SOKTools with my SunGoldPower batteries.
7E 32 35 30 31 34 36 43 31 30 30 30 30 46 44 39 41 0D
7E = SOI or Start Of Information and is 126 decimal or the tilde (~) character
32 35 = Protocol version 0x25 (32=2 and 35=5)
30 31 = Battery address 1 (30 = 0 and 31 = 1)
34 36 = CID1 (34 = 4 and 36 = 6)
0D = EOI or End of information which is also a carriage return
Hopefully your data will be like these.
000001: 2024-05-14 17:51:49.2299054 +0.0862495
7E 32 35 30 31 34 36 43 31 30 30 30 30 46 44 39 ~250146C10000FD9
41 0D A.
000122: 2024-05-14 17:51:49.4688859 +0.1447872
7E 32 35 30 31 34 36 43 32 30 30 30 30 46 44 39 ~250146C20000FD9
39 0D 9.
000322: 2024-05-14 17:51:49.7569071 +0.1477075
7E 32 35 30 31 34 36 34 32 45 30 30 32 30 31 46 ~25014642E00201F
44 33 30 0D D30.
000648: 2024-05-14 17:51:50.1250524 +0.1546539
7E 32 35 30 31 34 36 34 34 45 30 30 32 30 31 46 ~25014644E00201F
44 32 45 0D D2E.
000842: 2024-05-14 17:51:50.4290855 +0.1612600
41 0D A.
000964: 2024-05-14 17:51:50.6680950 +0.1446735
