Back on subject, what is the advantage of an high voltage battery for you instead of a regular/safe/easy to build 48V?
My thoughts on this:
I am planning an ICE to EV conversion, and could pick any suitable battery type and voltage I like. I could source a wrecked EV and reuse it's battery/motor/controller and I likely will go this route, if I can source the required wreck. Likely the wreck will not be LiFePO4 chemistry. To have LiFePO4, I could build 7 x 16S packs and series connect them to get 360vDC for the EV, however there are issues with series connecting the 48v packs, and having a suitable BMS for each pack that will support the series connections, and a master to control them all.
A simpler method available is a single high cell count BMS that can control 112 cells, and maintain their balance without series connecting smaller packs, and make use of safe LiFePO4 cells.
My ESS home solar system is currently using 48v (16-S) packs. It could be charged with an Inverter that supports high voltage DC MPP inputs and supply that input from the EV instead of a high voltage PV string.
Available currently are also HVDC inverters, that would operate with an energy storage battery at 360v.
If the EV and ESS are both 360vDC, this would very much simplify rapid charging the EV, or the ESS, without expensive commerical DC chargers required, only control over the current flow. Additional equipment/machinery/systems that all use the same chemistry and voltage would share similar advantages and allow further back-ups to the ESS/EV/other.
If the Mazda EV conversion is built with a battery, fixed between the frame rails (for example) and has say a 160 mile range, but an additional identical voltage and chemistry battery pack is available, that can fit into the truck box, be secured and plugged in when longer range is needed, increasing the truck range to 320 miles wouldn't this 'modular' battery system be worth investigation? Effectively you don't have to choose a long range or standard EV, you can have both, and for daily commuting, not drag around the heavier long range battery, only install that when needed. Leave the spare extra-range pack on a rack in the shop where it is connected to the ESS as a dump-load for the stationary system. In winter, when no dump load is required, the spare pack can be charged overnight on our new Ultra-low-rate 2.4cents/kWh 11:00pm to 7:00am rate and be the emergency power when the utility is down during winter storms.
Say this same mobile 360vDC battery can fit into an off road vechical, and or a farm tractor, and or a house boat, or just sit on the rack in my work shop to add winter-time capacity to my existing ESS system, or power my neighbour's house in an emergency. (yes I have a fork lift and other equipment capable of lifting/manipulating such a heavy battery) could this not be a super versatile modular power system, using low risk LiFePO4 cells, and currently available parts?
Maybe I am just dreaming, but it seems worth the time to discuss and think about a modular system. I'd like to call it the "
ESC-360" {Energy Storage Cell - 360 (360-voltage, and the idea is can be "turned 360-degrees to operate anything") and build about ten things it can fit into and just plug in and go.
