There is no such thing as a "Victron Venus." There is a Phoenix.
"efficiency" is misleading. It is a MAXIMUM, and it only exists at one point on the power curve - usually about 30% of continuous rating.
100W on a 300W inverter is likely to be at nearly the maximum efficiency.
100W on a 3000W inverter is going to be decent.
100W on a 5000W inverter is going to be much lower than you think it should be..
The above is pretty typical for all inverters.
As others have mentioned, the other side of the coin is idle draw. If you're going cheap, you may pay the price with high idle load.
A typical Voltronics-type 48V/3000W inverter has an idle burn of 40-50W
continuous even if no loads are used.
A typical tier 1 inverter (Victron, outback, midnite, magnum, schneider, etc. - all the expensive ones) are going to have a very low idle draw - probably around 0.6% of rated capacity. You pay for that.
So, which is better?
A "95% efficient" inverter that burns 40W continuously
A "90% efficient" inverter that burns 11W continuously
Efficiency numbers are not consistent either. Some manufacturers factor idle consumption, some don't.
So, asking for "the most efficient" inverter may not get you the answer you want.
