House burned down
Anybody care to speculate why the blue sea fuse holder says this if that is not true?
A fuse like a Class-T can in some circumstances 'explode' in the sense that sand and bits of metal can come flying off in case of a short. They quench the arc very well, but in the process there might be some 'mechanical deformations' so to speak. The cover over the fuse holder keeps these bits in one place.
Doesn't happen often, but it's possible. By the way, this is a direct short and how a Class T deals with it (without the explosion - the sparks are from the contact):
It isn't ridiculous now is it? Afterall, more is better and more after that is even better yet.
This is what you sound like reading the comments.
Rant over. :)
What, Me sound like?
If multiple strings are in parallel, can one bad one get cooked and vent, without fuses blowing to isolate it?
I suggest isolating bad string of cells in the event problems are detected. Contactor or shunt-trip breaker, under control of BMS.
Relevant note. I was hooking up my blue Sea class T fuse and holder, and there is a sticker on the cover that says something like explosion proof when cover in place. This indicates to me that the class T fuse contained within the holder is not ignition proof without the cover, I’ll get a photo next time. I’m up there.
Are you stuck in a time loop? ;) ... or is this the Matrix all over again.
National Electrical Code (NEC) 2020
The container in that context is the smallest element that is dealt with in the field for a raw battery, like a 12v brick. When you have a UL 48V pack that does not need a "container," but it could require spill containment.
Cell - single electrolytic unit
Module - assembly of one or more cells into a UL package
String - series collection of cells or modules with a single external current path
Battery - collection of one or more strings for a complete system.
Being that people use a single 12 volt car battery with cables to weld in the field, it’s very possible.
"He never actually touches the other post and then he draws the arc"
I don't buy the part about it jumping an airgap to initiate the arc either.
Higher voltage needed to ionize air and make a spark.
Once you've got an arc, then you can pull it.
(But I'm not good under 125A on my 80Vrms buzz box.)
ok I have only welded for about 40+ years at this point in my life. when using DC current for welding the object is to start the arc without touching the base metal. professional welders do that all the time. beginners drag the electrode across the base metal to start the current flowing.
ever watched a tig welder? you hold the tip of the electrode about 1/8" and start welding. thats from a low of 5-10 volts for really thin metal, up to the limits of your welder. if you are running say 48 volts that gap can be as large as your shielding gas will cover.
Forgot to add this csst gas line is reported as cause of that gas line failure … something about…. some how during storm …. lightning went through popped hole.
“Gas line and popped a hole in it.” This csst type gas line is reported cause fires all over USA and was common in homes and is still sold. They say it was not bonded correctly…why lightning takes it out when strike happens nearby. They say it is .008” thick wall. Still sold all across the country.
Example …. Stored energy is dangerous. Got csst flex type gas lines in your home? The way some connections are made it is impossible to really bond it. So…… if home had fire place in that hoa it had csst.
The Arson was most likely the maker of the csst type gas line in described home for last post. Installer gets the blame. Buy beware.
Caveat emptor
That csst is builder - govt approved.
yeah they use that stuff here in japan as well, but the regulator for the gas is designed that if it flows gas over X amount in x time shut off. it is set to see sudden large amounts in the case of a ruptured pipe, or a low/slow amount over a period of time. slow leaks. the damn regulator costs more than the two propane tanks cost
it can be a real pain in the ass when roasting a turkey or a ham in the US oven. had to put in special paperwork to get them to reprogram it to accept how a US gas oven works.
Reactions: D71
Likewise We are in effect R&D field techs testing this home power generation storage - equipment long term. We assume the risk. We allowed it into our homes as risk but supposed control safe with practices. We also drop our guard vs vigilant to be on look out smug in ourselves - comfortable. About that time is when we get a bite…. Or feel the burn.
yep perfectly explained.
There is a fresh post on this forum of a bms fire most likely from lightning hitting inverter. Fused breaker. Got bms too but bms is getting fault due to name - DALY by some reading and responding. So…. They fail too but lightning hitting inverter most likely started all of it. My factory pack batteries have bms on each 12 volt battery with blue tooth and NOW would not have batteries without blue tooth to monitor. My system is small on purpose. There are also limits to batteries.
that and people saying that you can't arc DC without touching the wires or contacts...
Ppl get mad at me for my opinion - they are fragile ego monsters …
Ego is the biggest issue on this forum, thats why I post every single screw up I have. no Ego to deal with... just honesty.
No one got hurt or killed in this post was good over all thing.
Best thing about this post... though I think the OP needs to pay homage to a really kind deity.
I think the batrium looks great for specs. 200+ cells monitoring is fantastic.
I considered this 10x10 shipping container but there are no bargains - wood floors.
Put some panels on sides and top. 👀
The 10x10 cost is about 10x20 which is about cost of 10x40. 😳
I’ve got breaker with lower rating then fuse as final fail safe for my batteries. My Batteries are manufactured packs in metal locker. Each is 12 volt heaters and blue tooth…4 bms. Not UL mine are emergency. If buying again would of bought UL everything.
don't know about your area, but here in Japan, the smaller containers are more expensive used as you can load them on a truck with a UNIC,(truck mounted crane) or a small forklift. the 40's cost less used as you need a crane to load and offload. its all about the economics of the situation.
Reactions: D71
That's called HF start. It sends high voltage pulse (few kV) through the torch to start the arc without tip touching the work piece. Is activated by trigger button on the torch or using lift start function.
technically you are correct, but I have a miller dynasty 200 and I have rarely needed to use the high frequency start and I never use the touch and lift start... too easy to contaminate your electrode that way. pedal or finger trigger, I ramp the voltage up, it jumps and I lower the voltage down.
Great thread for DIY education! I'm probably the worst setup regarding safety of any with my build. I am running 14s100p 18650s fused with the tiny wires on each cell. I just added 16s lifeP04 280ah string. I only go to 3.45v on charging which is 52.1v. I have limit of 80amps on charging 70amps discharging with Sol-Ark 8K. These batteries are in parallel. 8kwh PV total. I power 10 circuit transfer box. Biggest draw is 900watt 120v split air AC. Coffee make about 2700 watts, but only last for less than a minute. Air fryer is next biggest load almost 15amps @ 2900 watts.
Sol-Ark is mounted on 3/4" plywood. 18650s are mounted on metal sheet bolted to 3/4" plywood. LifeP04s on shelf rated for 400lbs. It is on wheels but I don't move it. I made plexiglass covers for each 8 cell section. Barley paper for separators and clamped at charge of 3.36v lightly.
No one on this thread spoke to the OP going above 3.55v per cell??
