I'm considering ground mounting a 10kW system in the field next to my house. To hook it up to the house, I need to run it underground in the field for ~10 meters, then (I imagine) along the underside of bridge going over a small stream for ~5meters, and finally another 25 meters to the house.
The question is, what rules apply in the U.K. for cable runs between arrays and the hook-up to the house?
Can I surface the cable by the bridge, tack it the wooden bridge underside and then bury it again?
Thanks
I'm not a sparky, but understand that BS7671 will apply.
You have only specified "system" and "cable" without it being clear whether you want to run PV cable (dc) from panels to an inverter in the house, or whether the "system" comprises both panels an inverter and you want to get 230V AC back to the house.
Assuming the former (which is more logical from carry power over a distance) then PV cable itself is not suitable for direct burial - it will need to be in double walled ducting as minimum, correctly coloured and to the required safe depth. There will need to be warning tape below ground, but above the ducting too.
Unless the location is a specific case covered by BS7671 (such as a campsite) then the key consideration is whether the cable will be safe from external interference, so my concerns with coming up and across the bridge would be protection not only from water ingress, but from physical damage - e.g. someone brush-cutting weeds at ground level by the bridge. Hence, metal conduit would be advisable, but then you would also need to be able to achieve a water-tight joint underground between the metal conduit and remaining, presumably double skinned plastic, ducting for the remaining run.
If the bridge is not sturdy, IMHO it would be better to go underground or have a completely separate metal conduit structure to carry the cables, suitably labelled, of course.
If, on the other hand, you want to transmit mains power back, then SWA of maximum size would suffice for direct burial and not require extra complexity around the bridge.
