I THINK the gist is an attempt to give examples of battery chemistry choices and results.What does this conversation have to do with OP's questions? I'm lost.
The OP is 71. BattleBorn batteries are quite likely to outlive the OP if treated well. The OP will hopefully outlive lead acid batteries. I hate using lead acids in a mobile environment. Weight, off-gassing, etc.
Sorry about your dad. Mine died too when I was young and he did electrical. But did you figure out the amount of time you will use each appliance daily so you have enough in battery storage? Well, if you buy an all in one to start like I posted here, (or from elsewhere) it will get you through with minimal appliances for sure, i.e,. Laptop, LED light, fan (get a usb one or DC (plug in cigarette lighter socket), maybe a small electric blanket (low watt). I have one that has a 10 amp fuse attached to the DC cord. (They use a lot of power). And are you using butane or propane to cook?
I left you a link ^^ to Bob's youtube channel in previous posts above about the insulation. He shows you exactly what to use and it's not that expensive. Here is a specific video where they go in detail to do the entire van/panels:Thanks Santa. I'm pretty desperate right now since I have to be out of here in 2 days and it looks like there's no way that's gonna happen due to 19 years of accumulated stuff in my apartment. Right now I'm just trying to figure out a reasonably powerful solar system that uses remote panels that could eventually be mounted to the roof of a larger van. I watched one of Will's vlogs today about Ruixu LiFePO4 batteries. I'm thinking that with at least 2 of those, I could have the beginnings of a pretty beefy system that could eventually transfer to a larger rig. But, of course, I'm only the "daughter" of a master electrician, and have "0" understanding of what it would take to build a complete (transferable) solar system, with enough power to operate several 1000-1500 W appliances (not necessarily at the same time.) In the full size van I need an indoor shower with On-Demand hot water (maybe recirculating to avoid having to carry too much weight in water,) I also need to figure out an inexpensive but effective way to insulate and panel the inside of my transit connect. I guess once I have some sort of electrical system established, I will probably need to purchase an Instant Pot, which, I think, can provide me with the means to cook pretty much anything.
Not sure if I mentioned before, but I am semi-disabled as the result of a stroke that affected my entire dominant right side a couple years ago. And, I have 0 coordination in my left side.
Drive west! I bet the cost of living in rural New Mexico is about half or even less of the cost of living in Orlando. We have all the sun too 335 days on average.
To answer one of your questions, insulation slows the change of temperature. Hot or cold, doesn't matter-like a thermos.
Since you are in a time crunch and need portable power, Bob just reviewed this all-in-one today. I don't think Will did any vids on it. It does have a coupon code (look in the description notes) which needs to be used within a certain time. Check this out, and watch all of Will's videos to help you decide. I don't know if this will be enough for you, but to start, it could be a first system for you until you figure out what you want/need. First thing you need to do is figure out your load, what you need to power with electricity, make a list, and put the watts and how often you will use everything. V x A = W and V=volts, A=Amps, W=Watts P.S. Be aware its 48 pounds. Here's Bob's vid:
Go stay with your relatives until you get your rig set up properly. ??
Will this be use in travel time or will you live in it full time?
What vehicle do you have in mind so we can get an idea about roof size, etc?
How 'Stealth' do you want to be?
(Something you can park about anywhere and not be noticed)
I read a comment where it says thinsulate's good for blocking out sound, but not good for insulation. Like I said CheapRVLiving has a video on what to use to insulate here:
It might be good to post a picture of your new roof line and tell us what it's made from, to determine if a solar panel really is or isn't feasible up there. The fixed solar panels seem to be much cheaper than the portable ones. If your fan isn't yet installed it might make more sense to install it vertically through one of the back windows in case you really could put a panel on the roof. Will had a recent video where he tore down a lot of portable power units and it seemed like he was very positive about the Jackery.
For insulation an easy and effective solution appears to be thinsulate but it is not inexpensive. Check out this video.
Me too.New Mexico Will. Yes, for years I've been attracted to the Earthship movement near Taos.
