Pim57
- Mar 10, 2021
- 125
I feel sorry for you that you had to cut in your lovely rv in order to free the batteries!Last question, and i will add again that i had to cut off a part of my rv, one of the very last of this model in running and original condition.
Ive always been on pwm and switched to mppt, if i keep my pannels on 24v 200w on my surviving 12v battery, do i loose half power, good/bad/nvm conséquences, on a mppt? For now until in can fix it
But luckily your rv didn’t catch fire!
For a MPPT it doesn’t matter if the battery is 12 or 24 Volt. You don’t loose any power as you would with pwm.
MPPT is great for high voltage input, because this is where you run long cables to the solar and you want the amperage down as much as possible.
So if partly shading on your panels is not a problem, you want your panels in series to increase the voltage and lower the amperage.
Then mount the MPPT charger close to the battery in order to have short cabling and avoid voltage drop.
