I am in an off-grid situation. My inverter provides AC power to a distribution panel which then controls circuits for my cabin. My question has to do with bonding neutral and ground in my panel. My inverter has DC inputs and a ground connection (currently bonded to my ground busbar which connects to a ground rod). For outputs, it has 2 AC outlets as well as a terminal AC block (with Live, Neutral, and Ground outputs).
When I plug in a standard outlet tester into the built-in AC outlets on the inverter it shows open ground and the GFCI testing button does not trip the circuit. I am getting the same results on outlets that I power through the breaker box (and hence the inverter AC terminal block). I am using standard breakers (non-GFCI). From what I understand, the means that my circuits are not ground protected and any GFCI outlets will not function properly. I have wired in a GFCI outlet onto one circuit and it does not function as a GFCI.
I then tried bonded the neutral and ground busbar in my panel and my outlets now seem to function properly (circuit tester says all good and the GFCI trip function works properly). I understand that bonding the ground and neutral in a subpanel can be a bad idea, but I'm not sure why, or if it is appropriate here.
Any information around the safest way to work with the AC side is greatly appreciated!
System Details
- Completely Off-grid
- 6, 12V-200 W panels; 2 panels connected in series to produce 24V, each pair connected in parallel
- Renogy 60 A MPPT charge controller
- 4, 24V LiFePO 100 Ah Renogy batteries
- 24 V - 2000 W inverter: https://www.amazon.ca/dp/B081YVNZX1?starsLeft=1&ref_=cm_sw_r_apan_dp_ZKTRH6YQV1ZDYXD4MF75
System Details
