Absorb setting does not stop the charging, only limits the rise in voltage. When it reaches the setting, current will gradually fall. Hopefully your
inverter has an adjustable time limit for absorb. If left in absorb too long, it can overcharge one or more cells. I have a 12V system. You will have to experiment a bit but my absorb time is currently at 15 minutes. After the time is reached, it will drop the voltage to the float value. If the system has no load, yes , the charging will stop for a while but will resume once the voltage has fallen to the float value. Disable equalization setting if possible
If it cannot be disabled, change the setting to something below the float value if it allows you to go that low. Equalizing LIFEP04 cells is very bad.
