aunsafe2015
I've read a bit about people getting C/AFCI+GFCI breaker trips in their main panel when they are using a Reliance Controls manual transfer switch (MTS). I understand that this has something to do with neutral switching and/or neutral+ground bonding issues. Apparently the main panel breakers trip when switching the circuit from LINE to GEN (or maybe from GEN to LINE) on the MST.
Does anybody know if using a Tier 1 quality inverter (e.g., Victron or Sol-Ark) would eliminate these C/AFCI+GFCI breaker trips?
Or are C/AFCI+GFCI breaker trips in the main panel inevitable when using a Reliance Controls MST?
Thanks for any input. I'm in the middle stages of figuring out a battery backup system and debating between a Reliance Controls MST versus an interlock kit. The advantage of the MST would be that I could leave the breakers in GEN mode with the inverter in pass-through mode to have it operate as an automatic transfer switch / UPS at times. The benefit of the interlock kit would be access to every breaker in the panel and not having to worry about the neutral switching/bonding issues.
