chaosnature
- Sep 15, 2022
- 463
Set the 'discharge_knee_v' to 3.5 in your YAML, and it will work as expected now that you have set UVPR to 3.1v.
I'm glad we're understanding what went wrong, but I'm frustrated that you were quick to blame the code - these batteries are not toys (especially the li-ion cells you have) and incorrect BMS settings could lead to a dangerous fault condition.
You should always:
- Ensure the hardware is correctly and safely set up. Connections, wiring, etc, must always be safe.
- Ensure the BMS is correctly configured for your battery chemistry.
- Only then can you utilise a project like the JK-BMS to ESP32 correctly.
Also - I was not quick to blame the code and I don't do blame (as I know you guys did an intelligent hard work coming up with this solution) i initially stated it might have been something i touched at the start of logging my issues refer back to the beginning.
why would i blame the code when i have not a clue how to write simple arguments like you guys do.
i understand your frustration, but these things happen and yes i am very safe - i do think through my decisions both on paper and in my head multple times before i move to implementation.
