JK BMS not charging. 72v 80AH.
kevenlolo
Cavite, Philippines
I have my new JK BMS and configured accordingly on my needs. The problem here is that it does not accept charging. And worst thing is that the voltage discharge from BMS goes upto 100v. It should be 79v only since my battery is at 79 only.
I added settings screenshots and a screenshot from tester where red pin is connected to battery positive and black pin is connected to BMS P-. The abnormal voltage happens only when higher amps are being discharged, around at least 10A.
I hope someone could help me.
