Eclipse11
- Sep 26, 2019
- 12
Everything is hooked up correctly, 400 watt system, 1500 watt pure sine wave inverter, 50 amp mppt solar charge controller. Once connected to battery and solar I check my Mt-50 and shows the voltage at 12.6 for the battery, then shows Zero for the PV. I set the battery parameter at 90 amp hours-sealed. The PV then showed .5 but the sun had just gone down. The inverter is still not turning on and I'm thinking the parameters must be set correctly?? The mppt light is a stable green. No power on inverter.. anyone have ideas of how to get this working??
