Hi guys!
My first post here, so I guess I should give some background. I have no experience with solar but are on a steep learning curve. Will build an easy, small footprint, preferably lightweight solar system for my soon to be camper van. Actually I did not find Will's YouTube channel or this forum until yesterday, and it has been gold already, so thanks for that!
However, I am about to pull the trigger on some batteries when I stumbled across this one. It is sold at eBay/Amazon etc and I think that it could be a pretty new version, since I can not find that much information about it on the interwebz. Only found one review at Amazon, and that someone here on the forum bought one a couple of weeks ago (but no more info than that).
It is supposed to be 300Ah, 200A BMS, high and low cold temperature protected and weighs 26.6kg. It is really perfect for me spec-wise, but it also sounds a bit to good to be true? Unfortunately I do not really have a rig to test it, or the economy to buy one just to rip it open.
What do you think about it? All input is appreciated!
Some pictures and specs:
Capacity 300Ah
Battery Material Lithium Iron Phosphate(LiFePO4) battery
Nominal voltage 12.8V
Rated voltage 12V
Max Protection Voltage 14.6V
End Voltage 10V
Instantaneous discharge current ≥600A Continuous discharge current ≥300A
Size 385*190*245mm
Weight 26.6KG
Certificate CE ROHS MSDS UN38.3
Upgrade Parts/Accessories Grade A Voltage Protection Board(BMS) Yes
Cycles Life 4000 Cycles-100% 6000 Cycles-70%
Max Charge Current 1C
Workingtemperature -20 ~ 60 ℃
Charge temperature 0-45℃
Warranty 3years
And a link to Kepworth's website:
Capacity 300Ah
Rated voltage 12V
End Voltage 10V
Size 385*190*245mm
Weight 26.6KG
Warranty 3years
US DE STOCK 12V 300Ah LiFePO4 Battery Lithium Iron Phosphate Battery Built-in BMS For RV Campers Golf Trolling Motor Tax Free - KEPWORTH
US DE STOCK 12V 300Ah LiFePO4 Battery Lithium Iron Phosphate Battery Built-in BMS For RV Campers Golf Trolling Motor Tax Free Advantages: It has excellent safety peformance and high efficiency and stability woking performance than traditional Lead acid battery. Low self discharge rate: It can...
www.kepworth.com
