RobertWJones
- Jul 11, 2020
- 5
Sorry, if this is too far off-topic, I understand if it gets promptly moved to the bit bucket. I'm working to put together an economical Lithium battery replacement pack to power my C-PAP machine during backpacking to replace the two $200+ each battery packs I purchased initially, only several years back (they didn't last long at all). My current attempt at a DIY replacement is using 4 X 18650 UltraFire BRC 6800mAh batteries in series, since 13-14V minimum is needed to keep the machine running. However, initial attempt only ran machine for 20-30 minutes before depleting the batteries to approximately 12V total (under the required voltage to power the machine). I must admit, I didn't purchase a charger to top off the batteries, initially, but they measured about 3.7V each, so I figured they may not need to be charged. Commercial Li-ion pack, I initially purchased, is rated 14.4V, 5200mAH, 75wH, and ran the CPAP machine for approximately 3 nights when it was new, before requiring recharge. The commercial AC adapter for the C-PAP machines is spec'd at 18V DC / 1.67A, although I suspect machine is using well under the 1.67 amps. In reading, it appears that Samsung, Panasonic, or LG Li-ion 18650 batteries may be much better and perhaps up to the task, but I don't want to purchase them if there isn't a reasonable chance that they will work much better. Maybe I need to add additional batteries in parallel? It does not seem like the commercial pack is physically large enough to contain more than 8 cells, in total, however. Any thought or recommendations would be greatly appreciated.
