Hi, first post here, and new to the LiFePo4 world, but learning day by day.
I have replaced the AGM in my caravan (trailer) with a 135AH 12V LiFePo4, and in setting up and trouble shooting the biggest hurdle I am encountering is the seemingly inconsistent terminology used by manufacturers and others.
For example, I was instructed by someone to "lower the bulk", but my S.C.C. does not give me a definable parameter called "BULK" so that term must have one or more "other name/s"
Other terms like "Absorption" and "Constant Current" also don't appear on my S.C.C.
So I guessed that I can't be the only newby who is confronted by this double-speak, so I tried good old google and came up short there too :-(
Is there a list of the terms used, and their possible synonyms out there, and if not, can someone here please post with at least some of the common ones?
Just for the record, the S.C.C. that I am using (eSmart-3 by ipanda) has only the following user definable parameters:
Constant Voltage:
Float Voltage:
Boost Voltage:
Boost Charge Time:
Bat. O/voltage:
Bat. O/voltage recovery:
Bat. U/voltage:
Bat. U/voltage recovery:
Max. discharge current:
Maximum charge current:
Constant Voltage:
Float Voltage:
Boost Voltage:
Boost Charge Time:
Bat. O/voltage:
Bat. U/voltage:
