42OhmsPA
What's in a title?
Am I overthinking this or just being dumb?
Currently have 2 9s strings connected in parallel via combiner box to my TP6048. Everything is working great except I'm not generating enough power. (it's sad watching generation going lower and lower each day, come on solstice ?).
I want to add a 3rd string, looking at the specs I should be fine but want some reassurance and/or motivation.
String 1 is facing slightly SW, around 15 degrees
String 2 is facing W, around 20 degrees
String 3 would face S, maybe slightly SE to catch the sun earlier, at a 35-40 degree angle.
1 and 2 are roof mounted, 3 would be ground.
Current panels are used 315w QCells
New used panels would be 280w-330w depending what I can find locally or Santan that is close to current specs.
Thoughts, feedback and wisdom?
